ALTER PROCEDURE
ALTER PROCEDURE 语句用于在当前所选数据库中创建存储过程,与 MySQL 中 ALTER PROCEDURE 语句的行为类似。
- AlterProcedureStmt
- ProcedureName
- CharacteristicOpts
- CharacteristicOpt
- SecurityInfo
修改一个存储过程:
use test
delimiter $$
create procedure t1()
begin
select 1;
end $$
delimiter ;
show procedure status;
alter procedure t1 comment 'test';
show procedure status;mysql> use test
Database changed
mysql> delimiter $$
mysql> create procedure t1()
-> begin
-> select 1;
-> end $$
mysql> delimiter ;
mysql> show procedure status;
| Db | Name | Type | Definer | Modified | Created | Security_type | Comment | character_set_client | collation_connection | Database Collation |
| test | t1 | PROCEDURE | root@% | 2023-08-10 17:36:42 | 2023-08-10 17:36:42 | DEFINER | | utf8mb4 | utf8mb4_bin | utf8mb4_bin |
mysql> alter procedure t1 comment 'test';
| test | t1 | PROCEDURE | root@% | 2023-08-10 17:36:42 | 2023-08-10 17:36:42 | DEFINER | test | utf8mb4 | utf8mb4_bin | utf8mb4_bin |
