CALL
CALL 语句用于调用当前数据库中已创建的存储过程,与 MySQL 中 CALL 语句的行为类似。
- CallStmt
- ProcedureName
- parameterOpts
- ParameterOpt
调用存储过程:
use test
delimiter $$
create procedure t1()
begin
select 1;
select 2;
end $$
create procedure t2(inNum int)
begin
select inNum;
select 2;
end $$
delimiter ;
show procedure status;
call t1;
call t2(2);ysql> use test
Database changed
mysql> delimiter $$
mysql> create procedure t1()
-> begin
-> select 1;
-> select 2;
-> end $$
ERROR 1304 (42000): PROCEDURE t1 already exists
mysql> create procedure t2(inNum int)
-> begin
-> select inNum;
-> select 2;
-> end $$
mysql> delimiter ;
mysql> show procedure status;
| Db | Name | Type | Definer | Modified | Created | Security_type | Comment | character_set_client | collation_connection | Database Collation |
| test | t1 | PROCEDURE | root@% | 2023-08-10 17:36:42 | 2023-08-10 17:36:42 | DEFINER | test | utf8mb4 | utf8mb4_bin | utf8mb4_bin |
| test | t2 | PROCEDURE | root@% | 2023-08-10 17:47:13 | 2023-08-10 17:47:13 | DEFINER | | utf8mb4 | utf8mb4_bin | utf8mb4_bin |
2 rows in set (0.00 sec)
mysql> call t1;
| 1 |
| 1 |
mysql> call t2(2);
| inNum |
| 2 |
| 2 |
| 2 |
