CREATE PROCEDURE
CREATE PROCEDURE 语句用于在当前数据库中创建存储过程,与 MySQL 中 CREATE PROCEDURE 语句的行为类似。
CreateProcedureStmt
CREATE DEFINER = user PROCEDURE IfNotExists ProcedureName procParameters characteristics routineBody
procParameters
procParameter procParameter , procParameters
procParameter
IN param_name type OUT param_name type INOUT param_name type
type
Any valid MySQL data type exception json
ProcedureName
Identifier . Identifier
IfNotExists
IF NOT EXISTS
characteristics
characteristic characteristic , characteristics
characteristic
COMMENT string SQL SECURITY SecurityInfo
SecurityInfo
DEFINER INVOKER
routineBody
statement
BlockStmt
begin_label : BEGIN statementList END end_label
CaseStmt
CASE simpleCaseList ELSE statementList END CASE CASE case_value searchCaseLists ELSE statementList END CASE
simpleCaseList
simpleCase simpleCaseLists simpleCase
simpleCase
WHEN search_condition THEN statementList
searchCaseList
searchCase searchCaseList searchCase
searchCase
WHEN when_value THEN statementList
IfStmt
IF search_condition THEN statementList elseIfList ELSE statementList END IF
elseIfList
elseIf elseIfList elseIf
elseIf
ELSEIF search_condition THEN statementList
LoopStmt
begin_label : LOOP statementList END LOOP end_label
RepeatStmt
begin_label : REPEAT statementList UNTIL search_condition END REPEAT end_label
WhileStmt
begin_label : WHILE search_condition DO statementList END WHILE end_label
CloseCur
CLOSE cursor_name
DeclareVar
DECLARE varNames type DEFAULT value DECLARE handler_action HANDLER FOR conditionValues statement DECLARE cursor_name CURSOR FOR select_statement
varNames
varName varName , varNames
varName
string
conditionValues
conditionValue conditionValue , conditionValues
FetchInto
FETCH NEXT FROM cursor_name INTO varNames
OpenCur
OPEN cursor_name
ProcedureSQL
SelectStmt UpdateStmt InsertStmt DeleteStmt ShowStmt ExplainStmt CreateTableStmt AlterTableStmt DropTableStmt
statementList
statement ; statement ; statementList
statement
DeclareVar FetchInto OpenCur CloseCur WhileStmt RepeatStmt LoopStmt IfStmt CaseStmt BlockStmt ProcedureSQL
handler_action
CONTINUE EXIT UNDO
conditionValue
mysqlErrorCode SQLSTATE VALUE sqlstateValue SQLWARNING NOT FOUND SQLEXCEPTION
平凯数据库不支持以下语法 characteristic:LANGUAGE SQL,[NOT] DETERMINISTIC,{ CONTAINS SQL | NO SQL | READS SQL DATA | MODIFIES SQL DATA }。
参数含义举例
tidb_enable_procedure开启或者关闭 tidb 存储过程tidb_enable_procedure = ON
tidb_enable_sp_param_substitute是否开启存储过程内部变量查询下推tidb_enable_sp_param_substitute=ON
max_sp_recursion_depth存储过程最多支持多少次递归max_sp_recursion_depth = 125
stored_program_cache最多缓存多少个存储过程执行计划stored_program_cache = 256
创建一个存储过程:
use test
delimiter $$
create procedure t1()
begin
select 1;
end $$
delimiter ;
mysql> use test
Database changed
mysql> delimiter $$
mysql> create procedure t1()
    -> begin
    -> select 1;
    -> end $$
mysql> delimiter ;
