DROP PROCEDURE
DROP PROCEDURE 语句用于删除当前数据库中已创建的存储过程,与 MySQL 中 DROP PROCEDURE 语句的行为类似。
- DROPProcedureStmt
- IfExists
- ProcedureName
删除一个存储过程:
use test
delimiter $$
create procedure t1()
begin
select 1;
end $$
delimiter ;
show procedure status;
drop procedure t1;
show procedure status;mysql> use test
Database changed
mysql> delimiter $$
mysql> create procedure t1()
-> begin
-> select 1;
-> end $$
mysql> delimiter ;
mysql> show procedure status;
| Db | Name | Type | Definer | Modified | Created | Security_type | Comment | character_set_client | collation_connection | Database Collation |
| test | t1 | PROCEDURE | root@% | 2023-08-10 17:32:35 | 2023-08-10 17:32:35 | DEFINER | | utf8mb4 | utf8mb4_bin | utf8mb4_bin |
mysql> drop procedure t1;
Empty set (0.00 sec)
