SIGNAL
SIGNAL 语句提供 TiDB Server 返回 error 或者 warning 信息。
SignalStmt
SIGNAL conditionValue SET signalInformationItems
conditionValue
SQLSTATE VALUE sqlstateValue
signalInformationItem signalInformationItems signalInformationItem
conditionInformationItemName = simpleValueSpecification
CLASS_ORIGIN SUBCLASS_ORIGIN MESSAGE_TEXT MYSQL_ERRNO CONSTRAINT_CATALOG CONSTRAINT_SCHEMA CONSTRAINT_NAME CATALOG_NAME SCHEMA_NAME TABLE_NAME COLUMN_NAME CURSOR_NAME
signal SQLSTATE '02000';
ERROR 1643 (02000): Unhandled user-defined not found condition
signal SQLSTATE '02000' set MESSAGE_TEXT= 'xwsfq', MYSQL_ERRNO =  1234 ,COLUMN_NAME = 'xswasz',CONSTRAINT_NAME = 'xxxsas',CLASS_ORIGIN = 'xxxxx',SUBCLASS_ORIGIN= 'xxxxx',
CONSTRAINT_CATALOG='xzzasa',CONSTRAINT_SCHEMA='xxxzsaa',CATALOG_NAME='xxzsaa',SCHEMA_NAME='xZas',TABLE_NAME='xZsa',CURSOR_NAME='xazass'
signal SQLSTATE '02000' set MESSAGE_TEXT= 'xwsfq', MYSQL_ERRNO =  1234 ,COLUMN_NAME = 'xswasz',CONSTRAINT_NAME = 'xxxsas',CLASS_ORIGIN = 'xxxxx',SUBCLASS_ORIGIN= 'xxxxx', CONSTRAINT_CATALOG='xzzasa',CONSTRAINT_SCHEMA='xxxzsaa',CATALOG_NAME='xxzsaa',SCHEMA_NAME='xZas',TABLE_NAME='xZsa',CURSOR_NAME='xazass';
ERROR 1234 (02000): xwsfq
get  Diagnostics CONDITION 1 @a1 = CLASS_ORIGIN ,@b1 = SUBCLASS_ORIGIN,@c1 =MYSQL_ERRNO, @d1= MESSAGE_TEXT,@e1 = RETURNED_SQLSTATE;
select @a1,@b1,@c1,@d1,@e1;
| @a1   | @b1   | @c1  | @d1   | @e1   |
| xxxxx | xxxxx | 1234 | xwsfq | 02000 |
平凯数据库不兼容 Signal condition_name 语法。
