使用 TiUP 运维 DM 集群
本文介绍如何使用 TiUP 的 DM 组件运维 DM 集群。
如果你还未部署 DM 集群,可参考使用 TiUP 部署 DM 集群。
TiUP DM 组件的帮助信息如下:
tiup dm --help
Deploy a DM cluster for production
Usage:
  tiup dm [flags]
  tiup dm [command]
Available Commands:
  deploy      Deploy a DM cluster for production
  start       Start a DM cluster
  stop        Stop a DM cluster
  restart     Restart a DM cluster
  list        List all clusters
  destroy     Destroy a specified DM cluster
  audit       Show audit log of cluster operation
  exec        Run shell command on host in the dm cluster
  edit-config Edit DM cluster config
  display     Display information of a DM cluster
  reload      Reload a DM cluster's config and restart if needed
  upgrade     Upgrade a specified DM cluster
  patch       Replace the remote package with a specified package and restart the service
  scale-out   Scale out a DM cluster
  scale-in    Scale in a DM cluster
  import      Import an exist DM 1.0 cluster from dm-ansible and re-deploy 2.0 version
  help        Help about any command
Flags:
  -h, --help               help for tiup-dm
      --native-ssh         Use the native SSH client installed on local system instead of the build-in one.
      --ssh-timeout int    Timeout in seconds to connect host via SSH, ignored for operations that don't need an SSH connection. (default 5)
  -v, --version            version for tiup-dm
      --wait-timeout int   Timeout in seconds to wait for an operation to complete, ignored for operations that don't fit. (default 60)
  -y, --yes                Skip all confirmations and assumes 'yes'
查看集群列表
集群部署成功后,可以通过 tiup dm list 命令在集群列表中查看该集群:
tiup dm list
Name  User  Version  Path                                  PrivateKey
prod-cluster  tidb  ${version}  /root/.tiup/storage/dm/clusters/test  /root/.tiup/storage/dm/clusters/test/ssh/id_rsa
启动集群
集群部署成功后,可以执行以下命令启动该集群。如果忘记了部署的集群名字,可以使用 tiup dm list 命令查看。
tiup dm start prod-cluster
检查集群状态
如果想查看集群中每个组件的运行状态,逐一登录到各个机器上查看显然很低效。因此,TiUP 提供了 tiup dm display 命令,用法如下:
tiup dm display prod-cluster
dm Cluster: prod-cluster
dm Version: ${version}
ID                 Role          Host          Ports      OS/Arch       Status     Data Dir                           Deploy Dir
172.19.0.101:9093  alertmanager  172.19.0.101  9093/9094  linux/x86_64  Up         /home/tidb/data/alertmanager-9093  /home/tidb/deploy/alertmanager-9093
172.19.0.101:8261  dm-master     172.19.0.101  8261/8291  linux/x86_64  Healthy|L  /home/tidb/data/dm-master-8261     /home/tidb/deploy/dm-master-8261
172.19.0.102:8261  dm-master     172.19.0.102  8261/8291  linux/x86_64  Healthy    /home/tidb/data/dm-master-8261     /home/tidb/deploy/dm-master-8261
172.19.0.103:8261  dm-master     172.19.0.103  8261/8291  linux/x86_64  Healthy    /home/tidb/data/dm-master-8261     /home/tidb/deploy/dm-master-8261
172.19.0.101:8262  dm-worker     172.19.0.101  8262       linux/x86_64  Free       /home/tidb/data/dm-worker-8262     /home/tidb/deploy/dm-worker-8262
172.19.0.102:8262  dm-worker     172.19.0.102  8262       linux/x86_64  Free       /home/tidb/data/dm-worker-8262     /home/tidb/deploy/dm-worker-8262
172.19.0.103:8262  dm-worker     172.19.0.103  8262       linux/x86_64  Free       /home/tidb/data/dm-worker-8262     /home/tidb/deploy/dm-worker-8262
172.19.0.101:3000  grafana       172.19.0.101  3000       linux/x86_64  Up         -                                  /home/tidb/deploy/grafana-3000
172.19.0.101:9090  prometheus    172.19.0.101  9090       linux/x86_64  Up         /home/tidb/data/prometheus-9090    /home/tidb/deploy/prometheus-9090
Status 列用 Up 或者 Down 表示该服务是否正常。对于 DM-master 组件,同时可能会带有 |L 表示该 DM-master 是 Leader,对于 DM-worker 组件,Free 表示当前 DM-worker 没有与上游绑定。
缩容节点
缩容即下线服务,最终会将指定的节点从集群中移除,并删除遗留的相关数据文件。
缩容操作进行时,内部对 DM-master、DM-worker 组件的操作流程为:
  1. 停止组件进程
  2. 调用 DM-master 删除 member 的 API
  3. 清除节点的相关数据文件
缩容命令的基本用法:
tiup dm scale-in <cluster-name> -N <node-id>
它需要指定至少两个参数,一个是集群名字,另一个是节点 ID。节点 ID 可以参考上一节使用 tiup dm display 命令获取。
比如想缩容 172.16.5.140 上的 DM-worker 节点(DM-master 的缩容类似),可以执行:
tiup dm scale-in prod-cluster -N 172.16.5.140:8262
扩容节点
扩容的内部逻辑与部署类似,TiUP DM 组件会先保证节点的 SSH 连接,在目标节点上创建必要的目录,然后执行部署并且启动服务。
例如,在集群 prod-cluster 中扩容一个 DM-worker 节点(DM-master 的扩容类似):
  1. 新建 scale.yaml 文件,添加新增的 woker 节点信息:
    worker_servers:
      - host: 172.16.5.140
  2. 执行扩容操作。TiUP DM 根据 scale.yaml 文件中声明的端口、目录等信息在集群中添加相应的节点:
    tiup dm scale-out prod-cluster scale.yaml
    执行完成之后可以通过 tiup dm display prod-cluster 命令检查扩容后的集群状态。
滚动升级
滚动升级过程中尽量保证对前端业务透明、无感知,其中对不同节点有不同的操作。
升级操作
可使用 tiup dm upgrade 命令来升级集群。例如,以下示例将集群升级到 ${version},执行命令前,将 ${version} 替换为实际需要的版本:
tiup dm upgrade prod-cluster `${version}`
更新配置
如果想要动态更新组件的配置,TiUP DM 组件为每个集群保存了一份当前的配置,如果想要编辑这份配置,则执行 tiup dm edit-config <cluster-name> 命令。例如:
tiup dm edit-config prod-cluster
然后 TiUP DM 组件会使用 vi 打开配置文件供编辑(如果你想要使用其他编辑器,请使用 EDITOR 环境变量自定义编辑器,例如 export EDITOR=nano),编辑完之后保存即可。此时的配置并没有应用到集群,如果想要让它生效,还需要执行:
tiup dm reload prod-cluster
该操作会将配置发送到目标机器,滚动重启集群,使配置生效。
更新组件
常规的升级集群可以使用 upgrade 命令,但是在某些场景下(例如 Debug),可能需要用一个临时的包替换正在运行的组件,此时可以用 patch 命令:
tiup dm patch --help
Usage:
  tiup dm patch <cluster-name> <package-path> [flags]
Flags:
  -h, --help                   help for patch
  -N, --node strings           Specify the nodes
      --overwrite              Use this package in the future scale-out operations
  -R, --role strings           Specify the role
      --transfer-timeout int   Timeout in seconds when transferring dm-master leaders (default 600)
Global Flags:
例如,有一个 DM-master 的 hotfix 包放在 /tmp/dm-master-hotfix.tar.gz,如果此时想要替换集群上的所有 DM-master,则可以执行:
tiup dm patch prod-cluster /tmp/dm-master-hotfix.tar.gz -R dm-master
或者只替换其中一个 DM-master:
tiup dm patch prod-cluster /tmp/dm--hotfix.tar.gz -N 172.16.4.5:8261
导入和升级由 DM-Ansible 部署的 DM 1.0 集群
引入 TiUP 前,DM-Ansible 用于部署 DM 集群。要使 TiUP 接管由 DM-Ansible 部署的 DM 1.0 集群,需要执行 import 命令:
例如,以下命令可导入使用 DM-Ansible 部署的集群:
tiup dm import --dir=/path/to/dm-ansible --cluster-version ${version}
可以执行 tiup list dm-master 来查看 TiUP 支持的最新集群版本。
import 命令的执行过程如下:
  1. 根据之前使用 DM-Ansible 部署的 DM 集群,TiUP 生成一个拓扑文件 topology.yml。
  2. 确认拓扑文件生成后,你可以用这个文件来部署 v2.0 或更高版本的 DM 集群。
部署完成后,执行 tiup dm start 命令来启动集群和开始 DM 内核升级流程。
查看操作日志
操作日志的查看可以借助 audit 命令,其用法如下:
Usage:
  tiup dm audit [audit-id] [flags]
Flags:
  -h, --help   help for audit
在不使用 [audit-id] 参数时,该命令会显示执行的命令列表,如下:
tiup dm audit
ID      Time                  Command
4D5kQY  2020-08-13T05:38:19Z  tiup dm display test
4D5kNv  2020-08-13T05:36:13Z  tiup dm list
4D5kNr  2020-08-13T05:36:10Z  tiup dm deploy -p prod-cluster ${version} ./examples/dm/minimal.yaml
第一列为 audit-id,如果想看某个命令的执行日志,则传入这个 audit-id:
tiup dm audit 4D5kQY
在集群节点机器上执行命令
exec 命令可以很方便地到集群的机器上执行命令,使用方式如下:
Usage:
  tiup dm exec <cluster-name> [flags]
Flags:
      --command string   the command run on cluster host (default "ls")
  -h, --help             help for exec
  -N, --node strings     Only exec on host with specified nodes
  -R, --role strings     Only exec on host with specified roles
      --sudo             use root permissions (default false)
例如,如果要到所有的 DM 节点上执行 ls /tmp,则可以执行:
tiup dm exec prod-cluster --command='ls /tmp'
集群控制工具 (dmctl)
TiUP 集成了 DM 的控制工具 dmctl:
运行命令如下:
tiup dmctl [args]
指定 dmctl 版本。执行如下命令前,将 ${version} 修改为实际需要的版本。
tiup dmctl: ${version} [args]
例如,以前添加 source 命令为 dmctl --master-addr master1:8261 operate-source create /tmp/source1.yml,集成到 TiUP 中的命令为:
tiup dmctl --master-addr master1:8261 operate-source create /tmp/source1.yml
使用中控机系统自带的 SSH 客户端连接集群
在以上所有操作中,涉及到对集群机器的操作都是通过 TiUP 内置的 SSH 客户端连接集群执行命令,但是在某些场景下,需要使用系统自带的 SSH 客户端来对集群执行操作,比如:
  • 使用 SSH 插件来做认证
  • 使用定制的 SSH 客户端
此时可以通过命令行参数 --native-ssh 启用系统自带命令行:
  • 部署集群:tiup dm deploy <cluster-name> <version> <topo> --native-ssh,其中 <cluster-name> 为集群名称,<version> 为 DM 集群版本(例如 v7.1.8-5.2),<topo> 为拓扑文件路径
  • 启动集群:tiup dm start <cluster-name> --native-ssh
  • 升级集群:tiup dm upgrade ... --native-ssh
所有涉及集群操作的步骤都可以加上 --native-ssh 来使用系统自带的客户端。
也可以使用环境变量 TIUP_NATIVE_SSH 来指定是否使用本地 SSH 客户端,避免每个命令都需要添加 --native-ssh 参数:
export TIUP_NATIVE_SSH=true
# 或者
export TIUP_NATIVE_SSH=1
# 或者
export TIUP_NATIVE_SSH=enable
若环境变量和 --native-ssh 同时指定,则以 --native-ssh 为准。
