DROP [GLOBAL|SESSION] BINDING
DROP BINDING 语句用于删除指定的 SQL 绑定。绑定可用于将优化器 Hint 插入语句中,而无需更改底层查询。
BINDING 语句可以在 GLOBAL 或者 SESSION 作用域内删除执行计划绑定。在不指定作用域时,默认的作用域为 SESSION。
DropBindingStmt
DROP GlobalScope BINDING FOR BindableStmt USING BindableStmt SQL DIGEST StringLiteralOrUserVariableList
GlobalScope
GLOBAL SESSION
BindableStmt
SelectStmt UpdateStmt InsertIntoStmt ReplaceIntoStmt DeleteStmt
StringLitOrUserVariable StringLiteralOrUserVariableList , StringLitOrUserVariable
stringLiteral UserVariable
你可以根据 SQL 语句或 SQL Digest 删除绑定。
根据 SQL Digest 删除绑定时,你需要指定相应的 SQL Digest:
  • 既可以通过字符串字面量来指定,也可以通过字符串类型的用户变量来指定。
  • 可以指定多个字符串,同时每个字符串也可以包含多个 digest,注意字符串之间和 digest 之间均需使用逗号隔开。
下面的示例演示如何根据 SQL 语句删除绑定。
CREATE TABLE t1 (
    id INT NOT NULL PRIMARY KEY auto_increment,
    b INT NOT NULL,
    pad VARBINARY(255),
    INDEX(b)
Query OK, 0 rows affected (0.07 sec)
INSERT INTO t1 SELECT NULL, FLOOR(RAND()*1000), RANDOM_BYTES(255) FROM dual;
Query OK, 1 row affected (0.01 sec)
Records: 1  Duplicates: 0  Warnings: 0
INSERT INTO t1 SELECT NULL, FLOOR(RAND()*1000), RANDOM_BYTES(255) FROM t1 a JOIN t1 b JOIN t1 c LIMIT 100000;
Query OK, 1 row affected (0.00 sec)
Query OK, 8 rows affected (0.00 sec)
Records: 8  Duplicates: 0  Warnings: 0
Query OK, 1000 rows affected (0.04 sec)
Records: 1000  Duplicates: 0  Warnings: 0
Query OK, 100000 rows affected (1.74 sec)
Records: 100000  Duplicates: 0  Warnings: 0
Query OK, 100000 rows affected (2.15 sec)
Query OK, 100000 rows affected (2.64 sec)
SELECT SLEEP(1);
| SLEEP(1) |
|        0 |
1 row in set (1.00 sec)
ANALYZE TABLE t1;
Query OK, 0 rows affected (1.33 sec)
EXPLAIN ANALYZE SELECT * FROM t1 WHERE b = 123;
| id                            | estRows | actRows | task      | access object        | execution info                                                            | operator info                     | memory         | disk |
| IndexLookUp_10                | 583.00  | 297     | root      |                      | time:10.545072ms, loops:2, rpc num: 1, rpc time:398.359µs, proc keys:297  |                                   | 109.1484375 KB | N/A  |
| ├─IndexRangeScan_8(Build)     | 583.00  | 297     | cop[tikv] | table:t1, index:b(b) | time:0s, loops:4                                                          | range:[123,123], keep order:false | N/A            | N/A  |
| └─TableRowIDScan_9(Probe)     | 583.00  | 297     | cop[tikv] | table:t1             | time:12ms, loops:4                                                        | keep order:false                  | N/A            | N/A  |
3 rows in set (0.02 sec)
CREATE SESSION BINDING FOR
   USING
    SELECT * FROM t1 IGNORE INDEX (b) WHERE b = 123;
| TableReader_7           | 583.00    | 297     | root      |               | time:222.32506ms, loops:2, rpc num: 1, rpc time:222.078952ms, proc keys:301010 | data:Selection_6   | 88.6640625 KB | N/A  |
| └─Selection_6           | 583.00    | 297     | cop[tikv] |               | time:224ms, loops:298                                                          | eq(test.t1.b, 123) | N/A           | N/A  |
|   └─TableFullScan_5     | 301010.00 | 301010  | cop[tikv] | table:t1      | time:220ms, loops:298                                                          | keep order:false   | N/A           | N/A  |
3 rows in set (0.22 sec)
SHOW SESSION BINDINGS\G
Original_sql: select * from t1 where b = ?
    Bind_sql: SELECT * FROM t1 IGNORE INDEX (b) WHERE b = 123
  Default_db: test
      Status: using
 Create_time: 2020-05-22 14:38:03.456
 Update_time: 2020-05-22 14:38:03.456
     Charset: utf8mb4
   Collation: utf8mb4_0900_ai_ci
DROP SESSION BINDING FOR SELECT * FROM t1 WHERE b = 123;
| IndexLookUp_10                | 583.00  | 297     | root      |                      | time:5.31206ms, loops:2, rpc num: 1, rpc time:665.927µs, proc keys:297  |                                   | 109.1484375 KB | N/A  |
| └─TableRowIDScan_9(Probe)     | 583.00  | 297     | cop[tikv] | table:t1             | time:0s, loops:4                                                        | keep order:false                  | N/A            | N/A  |
3 rows in set (0.01 sec)
Empty set (0.00 sec)
下面的示例演示如何根据 SQL Digest 删除绑定。
CREATE TABLE t1(a INT, b INT, c INT, INDEX ia(a));
CREATE TABLE t2(a INT, b INT, c INT, INDEX ia(a));
CREATE GLOBAL BINDING FOR SELECT * FROM t1 WHERE a > 1 USING SELECT * FROM t1 USE INDEX (ia) WHERE a > 1;
CREATE GLOBAL BINDING FOR SELECT * FROM t2 WHERE a < 1 USING SELECT * FROM t2 USE INDEX (ia) WHERE a < 1;
CREATE GLOBAL BINDING FOR SELECT * FROM t1 JOIN t2 ON t1.b = t2.a USING SELECT /*+ HASH_JOIN(t1) */ * FROM t1 JOIN t2 ON t1.b = t2.a;
SHOW GLOBAL BINDINGS;
方法一:
DROP GLOBAL BINDING FOR SQL DIGEST '31026623c8f22264fe0dfc26f29c69c5c457d6b85960c578ebcf17a967ed7893', '0f38b2e769927ae37981c66f0988c6299b602e03f029e38aa071e656fc321593', '3c8dfc451b0e36afd904cefca5137e68fb051f02964e1958ed60afdadc25f57e';
方法二:
SET @digests='31026623c8f22264fe0dfc26f29c69c5c457d6b85960c578ebcf17a967ed7893, 0f38b2e769927ae37981c66f0988c6299b602e03f029e38aa071e656fc321593, 3c8dfc451b0e36afd904cefca5137e68fb051f02964e1958ed60afdadc25f57e';
DROP GLOBAL BINDING FOR SQL DIGEST @digests;
Query OK, 0 rows affected (0.044 sec)
Query OK, 0 rows affected (0.035 sec)
Query OK, 0 rows affected (0.011 sec)
Query OK, 0 rows affected (0.013 sec)
Query OK, 0 rows affected (0.012 sec)
| Original_sql                                                              | Bind_sql        | Default_db | Status  | Create_time             | Update_time             | Charset | Collation       | Source | Sql_digest                                                       | Plan_digest |
| select * from `test` . `t1` join `test` . `t2` on `t1` . `b` = `t2` . `a` | SELECT /*+ HASH_JOIN(`t1`)*/ * FROM `test`.`t1` JOIN `test`.`t2` ON `t1`.`b` = `t2`.`a` | test       | enabled | 2024-08-11 04:06:49.953 | 2024-08-11 04:06:49.953 | utf8    | utf8_general_ci | manual | 31026623c8f22264fe0dfc26f29c69c5c457d6b85960c578ebcf17a967ed7893 |             |
| select * from `test` . `t2` where `a` < ?                                 | SELECT * FROM `test`.`t2` USE INDEX (`ia`) WHERE `a` < 1                                | test       | enabled | 2024-08-11 04:06:49.937 | 2024-08-11 04:06:49.937 | utf8    | utf8_general_ci | manual | 0f38b2e769927ae37981c66f0988c6299b602e03f029e38aa071e656fc321593 |             |
| select * from `test` . `t1` where `a` > ?                                 | SELECT * FROM `test`.`t1` USE INDEX (`ia`) WHERE `a` > 1                                | test       | enabled | 2024-08-11 04:06:49.924 | 2024-08-11 04:06:49.924 | utf8    | utf8_general_ci | manual | 3c8dfc451b0e36afd904cefca5137e68fb051f02964e1958ed60afdadc25f57e |             |
3 rows in set (0.001 sec)
Query OK, 3 rows affected (0.019 sec)
Empty set (0.002 sec)
DROP [GLOBAL|SESSION] BINDING 语句是 TiDB 对 MySQL 语法的扩展。
