LOCK STATS
LOCK STATS 语句用于锁定表或分区的统计信息,使得在锁定期间,TiDB 不会自动更新统计信息。具体行为请参见锁定统计信息的行为说明。
LockStatsStmt
LOCK STATS TableNameList TableName PARTITION PartitionNameList
TableNameList
TableName ,
TableName
Identifier . Identifier
PartitionNameList
Identifier ,
创建表 t,插入一些数据,在未锁定表 t 的统计信息的情况下成功执行 ANALYZE 语句。
mysql> CREATE TABLE t(a INT, b INT);
Query OK, 0 rows affected (0.03 sec)
mysql> INSERT INTO t VALUES (1,2), (3,4), (5,6), (7,8);
Query OK, 4 rows affected (0.00 sec)
Records: 4  Duplicates: 0  Warnings: 0
mysql> ANALYZE TABLE t;
Query OK, 0 rows affected, 1 warning (0.02 sec)
mysql> SHOW WARNINGS;
| Level | Code | Message        |
| Note  | 1105 | Analyze use auto adjusted sample rate 1.000000 for table test.t, reason to use this rate is "Row count in stats_meta is much smaller compared with the row count got by PD, use min(1, 15000/4) as the sample-rate=1" |
锁定表 t 的统计信息,执行 ANALYZE 语句,warning 提示跳过对表 t 的 ANALYZE。
mysql> LOCK STATS t;
mysql> SHOW STATS_LOCKED;
| Db_name | Table_name | Partition_name | Status |
| test    | t          |                | locked |
Query OK, 0 rows affected, 2 warnings (0.00 sec)
| Note    | 1105 | Analyze use auto adjusted sample rate 1.000000 for table test.t, reason to use this rate is "use min(1, 110000/8) as the sample-rate=1" |
| Warning | 1105 | skip analyze locked table: test.t        |
2 rows in set (0.00 sec)
另外,你也可以通过 LOCK STATS 语句锁定分区的统计信息。用例如下:
创建分区表 t,插入一些数据,在未锁定分区 p1 的统计信息的情况下成功执行 ANALYZE 语句。
mysql> CREATE TABLE t(a INT, b INT) PARTITION BY RANGE (a) (PARTITION p0 VALUES LESS THAN (10), PARTITION p1 VALUES LESS THAN (20), PARTITION p2 VALUES LESS THAN (30));
Query OK, 0 rows affected, 6 warning (0.02 sec)
| Warning | 1105 | disable dynamic pruning due to t has no global stats        |
| Note    | 1105 | Analyze use auto adjusted sample rate 1.000000 for table test.t's partition p0, reason to use this rate is "Row count in stats_meta is much smaller compared with the row count got by PD, use min(1, 15000/4) as the sample-rate=1" |
| Note    | 1105 | Analyze use auto adjusted sample rate 1.000000 for table test.t's partition p1, reason to use this rate is "TiDB assumes that the table is empty, use sample-rate=1"        |
| Note    | 1105 | Analyze use auto adjusted sample rate 1.000000 for table test.t's partition p2, reason to use this rate is "TiDB assumes that the table is empty, use sample-rate=1"        |
6 rows in set (0.01 sec)
锁定分区 p1 的统计信息,执行 ANALYZE 语句,warning 提示跳过对分区 p1 的 ANALYZE。
mysql> LOCK STATS t PARTITION p1;
| test    | t          | p1             | locked |
mysql> ANALYZE TABLE t PARTITION p1;
Query OK, 0 rows affected, 2 warnings (0.01 sec)
| Warning | 1105 | skip analyze locked table: test.t partition (p1)        |
解锁统计信息请参考 UNLOCK STATS。
该语句是 TiDB 对 MySQL 语法的扩展。
