INSERT
使用 INSERT 语句在表中插入新行。
InsertIntoStmt
INSERT TableOptimizerHints PriorityOpt IgnoreOptional IntoOpt TableName PartitionNameListOpt InsertValues OnDuplicateKeyUpdate
TableOptimizerHints
hintComment
PriorityOpt
LOW_PRIORITY HIGH_PRIORITY DELAYED
IgnoreOptional
IGNORE
IntoOpt
INTO
TableName
Identifier . Identifier
PARTITION ( Identifier , )
InsertValues
( ColumnNameListOpt ) ValueSym ValuesList SelectStmt ( SelectStmt ) UnionStmt SelectStmt ) ValueSym ValuesList SelectStmt UnionStmt SET ColumnSetValue , ColumnSetValue
ON DUPLICATE KEY UPDATE AssignmentList
CREATE TABLE t1 (a INT);
CREATE TABLE t2 LIKE t1;
INSERT INTO t1 VALUES (1);
Query OK, 1 row affected (0.02 sec)
INSERT INTO t1 (a) VALUES (1);
Query OK, 1 row affected (0.01 sec)
INSERT INTO t2 SELECT * FROM t1;
Query OK, 2 rows affected (0.01 sec)
Records: 2  Duplicates: 0  Warnings: 0
SELECT * FROM t1;
| a    |
|    1 |
|    1 |
2 rows in set (0.00 sec)
SELECT * FROM t2;
| a    |
|    1 |
|    1 |
INSERT INTO t2 VALUES (2),(3),(4);
Query OK, 3 rows affected (0.02 sec)
Records: 3  Duplicates: 0  Warnings: 0
SELECT * FROM t2;
| a    |
|    1 |
|    1 |
|    2 |
|    3 |
|    4 |
5 rows in set (0.00 sec)
INSERT 语句与 MySQL 完全兼容。如发现任何兼容性差异,请尝试 TiDB 支持资源。
