ADD COLUMN
ALTER TABLE.. ADD COLUMN 语句用于在已有表中添加列。在 TiDB 中,ADD COLUMN 为在线操作,不会阻塞表中的数据读写。
AlterTableStmt
ALTER IGNORE TABLE TableName AddColumnSpec ,
TableName
Identifier . Identifier
AddColumnSpec
ADD COLUMN IF NOT EXISTS ColumnName ColumnType ColumnOption FIRST AFTER ColumnName
ColumnType
NumericType StringType DateAndTimeType SERIAL
ColumnOption
NOT NULL AUTO_INCREMENT PRIMARY KEY CLUSTERED NONCLUSTERED GLOBAL LOCAL UNIQUE KEY GLOBAL LOCAL DEFAULT NowSymOptionFraction SignedLiteral NextValueForSequence SERIAL DEFAULT VALUE ON UPDATE NowSymOptionFraction COMMENT stringLit CONSTRAINT Identifier CHECK ( Expression ) NOT ENFORCED NULL GENERATED ALWAYS AS ( Expression ) VIRTUAL STORED REFERENCES TableName ( IndexPartSpecificationList ) Match OnDeleteUpdateOpt COLLATE CollationName COLUMN_FORMAT ColumnFormat STORAGE StorageMedia AUTO_RANDOM ( LengthNum )
CREATE TABLE t1 (id INT NOT NULL PRIMARY KEY AUTO_INCREMENT);
INSERT INTO t1 VALUES (NULL);
Query OK, 1 row affected (0.02 sec)
SELECT * FROM t1;
| id |
|  1 |
ALTER TABLE t1 ADD COLUMN c1 INT NOT NULL;
Query OK, 0 rows affected (0.28 sec)
SELECT * FROM t1;
| id | c1 |
|  1 |  0 |
ALTER TABLE t1 ADD c2 INT NOT NULL AFTER c1;
SELECT * FROM t1;
| id | c1 | c2 |
|  1 |  0 |  0 |
  • 不支持将新添加的列设为 PRIMARY KEY。
  • 不支持将新添加的列设为 AUTO_INCREMENT。
  • 对添加生成列有局限性,具体可参考:生成列局限性。
  • TiDB 对分区表进行了扩展,你可以在添加新列时通过将 PRIMARY KEY 或 UNIQUE INDEX 设置为 GLOBAL 来设置全局索引。该扩展与 MySQL 不兼容。
