DROP COLUMN
DROP COLUMN 语句用于从指定的表中删除列。在 TiDB 中,COLUMN 为在线操作,不会阻塞表中的数据读写。
AlterTableStmt
ALTER IGNORE TABLE TableName DropColumnSpec ,
DropColumnSpec
DROP COLUMN IF EXISTS ColumnName RESTRICT CASCADE
ColumnName
Identifier . Identifier . Identifier
CREATE TABLE t1 (id INT NOT NULL PRIMARY KEY AUTO_INCREMENT, col1 INT NOT NULL, col2 INT NOT NULL);
Query OK, 0 rows affected (0.12 sec)
INSERT INTO t1 (col1,col2) VALUES (1,1),(2,2),(3,3),(4,4),(5,5);
Query OK, 5 rows affected (0.02 sec)
SELECT * FROM t1;
| id | col1 | col2 |
|  1 |    1 |    1 |
|  2 |    2 |    2 |
|  3 |    3 |    3 |
|  4 |    4 |    4 |
|  5 |    5 |    5 |
5 rows in set (0.01 sec)
ALTER TABLE t1 DROP COLUMN col1, DROP COLUMN col2;
ERROR 1105 (HY000): can't run multi schema change
SELECT * FROM t1;
| id | col1 | col2 |
|  1 |    1 |    1 |
|  2 |    2 |    2 |
|  3 |    3 |    3 |
|  4 |    4 |    4 |
|  5 |    5 |    5 |
5 rows in set (0.00 sec)
ALTER TABLE t1 DROP COLUMN col1;
Query OK, 0 rows affected (0.27 sec)
SELECT * FROM t1;
| id | col2 |
|  1 |    1 |
|  2 |    2 |
|  3 |    3 |
|  4 |    4 |
|  5 |    5 |
  • 目前不支持删除主键列或组合索引相关列。
