DROP INDEX
DROP INDEX 语句用于从指定的表中删除索引,并在 TiKV 中将空间标记为释放。
DropIndexStmt
DROP INDEX IfExists Identifier ON TableName IndexLockAndAlgorithmOpt
IfExists
IF EXISTS
LockClause AlgorithmClause AlgorithmClause LockClause
CREATE TABLE t1 (id INT NOT NULL PRIMARY KEY AUTO_INCREMENT, c1 INT NOT NULL);
Query OK, 0 rows affected (0.10 sec)
INSERT INTO t1 (c1) VALUES (1),(2),(3),(4),(5);
Query OK, 5 rows affected (0.02 sec)
EXPLAIN SELECT * FROM t1 WHERE c1 = 3;
| id                      | estRows  | task      | access object | operator info                  |
| TableReader_7           | 10.00    | root      |               | data:Selection_6               |
| └─Selection_6           | 10.00    | cop[tikv] |               | eq(test.t1.c1, 3)              |
|   └─TableFullScan_5     | 10000.00 | cop[tikv] | table:t1      | keep order:false, stats:pseudo |
CREATE INDEX c1 ON t1 (c1);
Query OK, 0 rows affected (0.30 sec)
| IndexReader_6          | 0.01    | root      |                        | index:IndexRangeScan_5                      |
| └─IndexRangeScan_5     | 0.01    | cop[tikv] | table:t1, index:c1(c1) | range:[3,3], keep order:false, stats:pseudo |
2 rows in set (0.00 sec)
DROP INDEX c1 ON t1;
  • 不支持删除 CLUSTERED 类型的 PRIMARY KEY。要了解关于 CLUSTERED 主键的详细信息,请参考聚簇索引。
